Kiesel direct mount pickups adjustable?
BigMac2304
Postby BigMac2304 » Thu Jan 04, 2018 9:29 pm
Hi, just wondering if the direct mount pickups on the Aries A6 is adjustable or fix mounted? So if it is fix mounted we have to do the adjustments with a home made shim?
Also are pickup rings available as an option 50 on the Aries?
Re: Kiesel direct mount pickups adjustable?
Postby wickid » Fri Jan 05, 2018 7:10 am
On the few direct-mount p/ups I've had (DC747, at least), there is some sort of rubber-like tubing between the p/up base and wood. Acts like a spring.
Postby ElfDude » Fri Jan 05, 2018 9:07 am
Definitely adjustable.
Fear not. :)
Postby texastoast » Fri Jan 05, 2018 3:03 pm
On my builds there is a spring just like the bezel mounts. No rubber things however. They are just as adjustable as bezel mounts for the most part. You may be able to lower a bezel mount more but at that point it would be too low to be practical.
BigMac2304
Postby BigMac2304 » Fri Jan 05, 2018 10:38 pm
Okay, I'm relieved to know that it's adjustable. Because not all direct mount pickups are adjustable AFAIK.
