Could anyone please measure their Carvin/Kiesel for me?
speedyone
Postby speedyone » Thu Jan 11, 2018 2:18 pm
Hi all!
I’m looking into whether or not I can fit a new Flat Mount Floyd Rose on any existing Carvin or Kiesel which is using their tune-o-matic style bridge.
Floyd Rose customer service told me their new model of Floyd WILL fit, as long as there is the clearance for height. I will need 18.5mm (3/4") height from the body at the D string for the bridge to fit.
Could anyone please measure their Carvin/Kiesel which uses the tune-o-magic style bridge to see if there is adequate height?
Thanks guys for any help!!!
I’m looking to get an original H2 and mount the new Floyd on it.
Re: Could anyone please measure their Carvin/Kiesel for me?
Postby spudmunkey » Thu Jan 11, 2018 2:19 pm
Were you able to confirm that it would work with kiesel's TOM post spacing?
speedyone
Postby speedyone » Thu Jan 11, 2018 2:59 pm
Well, Floyd Rose customer service has a PDF:
https://cdn.shopify.com/s/files/1/1711/ ... 7680416961
Not sure if Carvin/Kiesel spacing will match....
Postby spudmunkey » Thu Jan 11, 2018 3:05 pm
So if I'm correct, this uses the TOM bridge itself, and not the stop-tail posts, correct?
I'll try to measure my CS6 when i get home. I will say that it was from 2008, so there's a CHANCE that they may have changed suppliers over the past 10 years, so perhaps someone else sees/responds with something more recent...
speedyone
Postby speedyone » Thu Jan 11, 2018 3:26 pm
Well, on the videos I have seen about installing the new Floyd, they took a Gibson SG, and another guitar with a standard tune-o-matic bridge, removed the original bridge, then just popped the Floyd into the existing holes.
I’ll post a link:
https://www.youtube.com/watch?v=hPc6fOYoNTY&app=desktop
Postby spudmunkey » Thu Jan 11, 2018 3:58 pm
Ahh...watching that video, I wouldn't trust my number because I only have the actual bridge posts, not the stop tail since it's string-through.
That said, I found the measurements for a roller bridge that 2 folks here have used as a drop-in replacement for their Carvin/Kiesel TOM, and it's slightly narrower than the string spacing on the Floyd brige:
Roller bridge string spacing span: 2" (50.8mm)
FRX string spancing span: 2.05" (52.1mm)
Here's the bridge that a couple of folks here have used:
http://www.stewmac.com/Hardware_and_Par ... ridge.html
speedyone
Postby speedyone » Thu Jan 11, 2018 4:20 pm
Thanks very much for checking into this!
I think I’m gonna call Kiesel tomorrow and just ask if the Floyd dimensions will work....
speedyone
Postby speedyone » Fri Jan 12, 2018 6:03 pm
Exciting news—
Talked to Albert, and after viewing the Floyd bridge specs, he said it should work in theory!
Now, to spec-out the new build...
Postby Greg Emm » Fri Jan 12, 2018 6:20 pm
:applause: Excellent news, man. Spud always comes through, and it sounds like Albert was able to fill in a fuller picture for you. I hope your quest for information leads you where you want to be. Good luck.
speedyone
Postby speedyone » Fri Jan 12, 2018 7:43 pm
Thanks!!
I had an H2 about 4 years ago. I loved it, but I have to use super light gauge strings— oo7 and 008– and I could never keep the guitar in tune with those gauges.
But now, being able to have a Floyd on it means I CAN use my strings I love, AND stay in tune!!!!
I can hardly wait!!!
Rialas
Postby Rialas » Sat Jan 13, 2018 1:26 am
Just watched the video, gosh that thing is ugly.
Just get a H2 with a wilkinson. I have one and it stays in tune well.
Rialas
Postby Rialas » Sat Jan 13, 2018 1:36 am
Or the hipshot contour as mentioned in your other thread.
It's subtle, less clutter, less to go wrong imo.
speedyone
Postby speedyone » Sat Jan 13, 2018 7:45 am
Though the Floyd may be ugly, there’s no chance a Wilkinson will say in tune with 007 or 008 gauge strings :)
009s or 010s maybe!
Plus, Carvin/Kiesel Wilkinson’s have always been a crapshoot; you never know if you’ll get a good or bad one.
