Semi-hollow & hollow interior shots
Postby spudmunkey » Sat May 17, 2014 7:59 pm
Since it comes up fairly often, here is a collection of shots showing the interiors of some of Carvin's hollow/semi-hollow guitars. If there are any more, please post 'me and I'll add 'em to the post!
AC175:
Image needed
AC275:
AC375:
*thanks kennym9898
https://www.youtube.com/watch?v=HN5q9UcmdpU
AC40:
AC50:
AE185:
Image needed
CC275:
CL450:
Image needed
H2:
Image needed
HF2:
HH1, HH2:
[edit: as of early 2016, this model has been updated, and has "revised chambering". The images below may no longer be accurate (or perhaps more accurately, are less likely to be accurate than before. :)]
NS1:
SB4001, SB5001: (discontinued model)
SH445, SH475, SH645, SH675, FG1:
SH550, SH575:
SH60, SH65:
SH250, SH275:
Cobalt C750s:
Brian D wrote:Image
re: Semi-hollow & hollow interior shots
Postby PastorDave » Sun May 18, 2014 4:25 pm
Now that's what I'm talking about, I wanted to see these before I got my SH60 but glad I went with it and now see the cut out is the same as the SH250 and that was one of my big questions no one seemed to be able to answer at the time so thank you I'm sure this will help many!
Sitedrifter
Postby Sitedrifter » Sun May 18, 2014 4:42 pm
Great information Spud!! Thank YOU!
Postby spudmunkey » Sun May 18, 2014 4:45 pm
I've just replaced the HH1/HH2 image with a more correct one.
The image below is NOT the actual chambering of that model. The pictures would indicate the pickups are mounted over a hollow area, but they are mounted to a solid wood area.
This is one that used to be out there, too, but is not correct with the production model:
Postby dbone » Sun May 18, 2014 7:28 pm
I came across a picture somewhere of the NS1 insides last week but I'll be dammed if I can find it now Ughh
Postby spudmunkey » Sun May 18, 2014 7:32 pm
I know, me too. It has a whole bunch of narrow horizontal channels, right?
Edit: I just took a bunch of screenshots from a vid from Carvin on YouTube. I'll piece 'em together into one composite image later...
I wonder if they took it off because the design has changed? :think:
Postby ElfDude » Sun May 18, 2014 9:35 pm
Awesome stuff. Thanks!
I wish there was one of the AE185...
Postby spudmunkey » Mon May 19, 2014 10:10 am
NS1 image was added. I swear there was one on the NS1's product page, but it's not there any more. This was pieced together from screenshots of the NS1 Steve Oliver demo vid on Carvin's Youtube channel. Perhaps it was removed because the design changed? :think:
Postby spudmunkey » Mon May 19, 2014 4:44 pm
SB4001/SB5001 added.
Postby Bob77 » Mon May 19, 2014 8:13 pm
Great idea to have all these pics on the same thread.
A lot more wood could be taken out from some of those models :mrgreen:
Postby spudmunkey » Mon May 19, 2014 8:43 pm
Actually...not a whole lot more!
On the AC models, that "solid" area is hollow from the back...that's the control cavity.
Hf2? Well...that's pretty darn hollow. :)
The HH has solid areas under the pickups to eliminate feedback issues. Remember that this model has pretty rounded-off edges, so the walls have to be thicker.
The SB couldn't really, either. The forearm contour has to remain pretty solid so that the bent wood has enough "meat" to stay glued down, and to keep its smooth contour, and one battery compartment is between the bridge and the bridge pickup, and the second battery compartment is to the right.
The carved-top SHs? Not likely. That's pretty darn hollow. :lol:
Now...on the SH60/65/250/275? I agree, there. The walls seem extra thick, considering the top is flat. The area behind the bridge is hollow from behind for the battery compartment, though, and it seems like those two center blocks are probably for feedback reduction. :thnk: the walls do seem thick, though.
Re: re: Semi-hollow & hollow interior shots
Postby spudmunkey » Tue May 20, 2014 9:30 pm
spudmunkey wrote:I've just replaced the HH1/HH2 image with a more correct one.
Ok, I think the previously-reported info was incorrect. :think:
After seeing the shots of vinbow's "spaltnut" factory shots, it does look like these really are the right cutouts!
I'll update the list above shortly.
Vinbow's factory shot:
vlnbow
Postby vlnbow » Tue May 20, 2014 9:57 pm
Here is the current cambering for the HH as previously confirmed with JK ..My "HH3's" have a completely solid center to acomadate the center pick up... changes the tone quite a bit.
Postby spudmunkey » Tue May 20, 2014 10:08 pm
Well. Dang...neither of them look right. :think:
I actually took that screenshot from the vid for that other thread...but then it doesn't look right bases on the other factory shots. :think:
Postby spudmunkey » Thu May 22, 2014 11:36 pm
feelthaflo wrote:Image
bandit2013
Postby bandit2013 » Fri May 23, 2014 3:38 am
This is a great thread. Thank you for sharing. :applause:
Guitars:CT624C, DC400W(2), DC200, DC400, DC100, CS6, CT6, BoltC (2), Cobalt 350s, Amps: Mesa Boogie Roadster, RA100, Mark V combo, Carvin V3MC, Mark Bass combo, Drums: Roland TD-15KV (extended kit),Recording: Tascam DP-32SD, RODE NT1-A, Shure SM57, EV RE320, Rivera Rock Crusher Recording
Lucidology
Re: Semi-hollow & hollow interior shots
Postby Lucidology » Fri May 23, 2014 11:43 pm
FG1:
[B]
Extremely cool ... that's even more hollowed out then I thought it was ..,
Love it!!
Postby gumbynotpokey » Sat May 24, 2014 3:37 am
Great thread, spud...very interesting.
Postby Bob77 » Sun May 25, 2014 8:50 am
spudmunkey wrote:Now...on the SH60/65/250/275? I agree, there. The walls seem extra thick, considering the top is flat. The area behind the bridge is hollow from behind for the battery compartment, though, and it seems like those two center blocks are probably for feedback reduction. :thnk: the walls do seem thick, though.
That's exactly what I was referring to in my post.
Postby spudmunkey » Wed Oct 08, 2014 11:37 am
AC375 user pics added (thanks for the images, Kennym9898!)
Users browsing this forum: hanzzen101 and 16 guests
