Trying to choose a top
YaiiE
Postby YaiiE » Fri Mar 16, 2018 12:44 pm
Hey guys! I was hoping you could help me with choosing a new top. I went with Flamed Maple for my first Kiesel. This time around I want to do something different for <$400.
The guitar's going to be a DC 600 with a deep moss green / trans green / gloss finish.
Swamp Ash
Black Limba
Spalted Maple
I can't choose!
Would you happen to have any pics of these tops, painted? For example: I saw a fair amount of Swamp Ash tops on Google but they were raw or glossed, un-painted.
With flamed maple I believe there's different tiers of tops: 4a - 6a? Are there varying tiers for all the tops or just the flamed maple? If I were to grab a Black Limba would it have consistent figuring? Or would there be an up charge for more a more consistent figuring?
One last question - The flamed maple top's book matched which is what causes that slight seam down the middle where the two pieces are glued together? These tops (swamp, black limba, spalted) aren't bookmatched so I assume they're one solid piece? No Seam?
Thank you!
Re: Trying to choose a top
Postby dbone » Fri Mar 16, 2018 9:34 pm
Well you could choose a black limba neck and body and then tell them that you do not want a “top wood” and then get moss green over the whole thing.. So that’s two black limba body wings glued to a black limba neck through. They typically make the efffort to make the pieces look good together but look at a few online.
Try googling Black limba moss green. A build like this in my opinion can often look better without getting a top wood. You might need to check with them but the DC600 without a top wood used to get a deeper arm relief contour.
Either way you can find a ton of builds photos with a few keywords searched on google photos
Swamp ash in AAT with moss green as well as spalted maple moss green can both look real good too.
I know it’s tuff to decide, the best thing you can do is lots of homework and look at lots of pics.
Postby Koshchei » Sat Mar 17, 2018 7:28 am
YaiiE wrote:Hey guys! I was hoping you could help me with choosing a new top. I went with Flamed Maple for my first Kiesel. This time around I want to do something different for <$400.
Swamp Ash
Black Limba
Spalted Maple
I can't choose!
Thank you!
Spalt
YaiiE
Postby YaiiE » Sat Mar 17, 2018 9:11 am
I’m 99.99% sure I’m going to go with Zebrawood. I was wondering if we could request a darker mahogany for the neck wood? Is there an up charge? I’ve seen quite a difference in color when it comes to mahogany. I was hoping to get a darker neck so it’d contrast better against the lighter Ash body.
Bovine
Postby Bovine » Sat Mar 17, 2018 10:25 am
I think this may cover all your bases. This is my DC700 and is my favorite of all my guitars:
Trans Moss Green
Zebrawood Top
Swamp Ash Body
5pc Mahogany Neck w/Maple Stripes
Zebrawood board
Unpainted Headstock
Best wishes to you man! I think you'll love it!
On Facebook.com/FoolsErrandRockBand Lyrics & Samples at: FoolsErrandRockBand.com
"Meaty enough for the mind, soothing enough for the soul"
YaiiE
Postby YaiiE » Sat Mar 17, 2018 1:03 pm
Bovine wrote:I think this may cover all your bases. This is my DC700 and is my favorite of all my guitars:
Trans Moss Green
Zebrawood Top
Swamp Ash Body
Zebrawood board
Unpainted Headstock
That’s beautiful!! And it was exactly what I was hoping to find!! Thank you!
Postby Doctor Turn » Sat Mar 17, 2018 1:10 pm
I tend to not think of limba as a top wood by itself. It's kind of like mahogany in the sense that when it's on a top, it's usually because the body is made of it also.. see the original Les Paul Customs (the real deal original Fretless Wonders. They had hog Honduras bodies and separate bound Honduran hog tops). The original standard Hagstrom Swedes, the 24.75 scale thingy of the seventies and eighties, were the exact same thing right down to the ebony fretboard.
Of course if you want to be decorative, you can get a thin slice of anything thrown in top of a slab body I guess. My theoretical cs3 will have a korina limba body and top, as well.
Bovine
Postby Bovine » Sun Mar 18, 2018 11:51 am
Trans Moss Green
Zebrawood Top
Swamp Ash Body
Zebrawood board
Unpainted Headstock
Yaaaayyyyy YaiiE!! Happy to help you out! Be sure to post your pics & specs once you pull the trigger. Would love my build to have a brother from another Kiesel mother out there somewhere! :D
Bovine
Postby Bovine » Sun Mar 18, 2018 12:02 pm
Doctor Turn wrote:I tend to not think of limba as a top wood by itself. It's kind of like mahogany in the sense that when it's on a top, it's usually because the body is made of it also.. see the original Les Paul Customs (the real deal original Fretless Wonders. They had hog Honduras bodies and separate bound Honduran hog tops). The original standard Hagstrom Swedes, the 24.75 scale thingy of the seventies and eighties, were the exact same thing right down to the ebony fretboard.
Would love to see that CS3 get built, Doc ---- I eventually would like to do an all limba build too, totally tung oiled. Such an inticing wood type!
