HSS wiring diagram for bolt plus
Ljensby
Postby Ljensby » Sat Feb 18, 2017 10:56 am
Didn't come with kit. Can't seem to find it on the web site. Any help?
Thanks
intrusted
Re: HSS wiring diagram for bolt plus
Postby intrusted » Sun Feb 19, 2017 8:05 am
http://www.carvinmuseum.com/pdf/guitarb ... wiring.pdf
Here's a link, hopefully of value for you
Carvin BK4A, BK5A, IC6WP
Carvin Amps RL1000 Micro MB12
BX1600-10.4
God gave me Life How can I deny Him my soul.
Postby wickid » Mon Feb 20, 2017 8:48 am
intrusted wrote:http://www.carvinmuseum.com/pdf/guitarbass/passivekit20-50guitarwiring.pdf
Man, I wish they still had a link to a manuals section. I think there may be a more current set of diags.
But a descriptive update to that 1 linked -
With the 4-conductor p/up leads, you wire White + Green where it currently indicates White.
Also, with the current 5-way, the lugs are thus:
Bridge, Mid, Neck, Common /then side B or 2/ Common, Bridge, Mid, Neck
Ljensby
Postby Ljensby » Tue Feb 21, 2017 12:00 pm
Thanks! I think that might be quite helpful.
mayor_of_pc
Postby mayor_of_pc » Tue Jan 30, 2018 12:08 pm
Here's a newer diagram with a bit more info:
https://www.kieselguitars.com/manuals/P ... ev2008.pdf
For my build, I used the Schaller Megaswitch E to get some pseudo humbucker combinations with the split bridge pickup
https://www.schaller-electronic.com/hp5 ... itch-E.htm
