Can you use alcohol based dyes over a tung oil finish ?
SomeGuitarGuy
Postby SomeGuitarGuy » Tue Apr 18, 2017 6:16 am
OK so i have a bolt neck that i had kiesel finish with tung oil about two years ago my question is can i use alcohol based dyes like Angelus leather dyes over the tung oil without any significant problems or would i have to sand off the tung oil to expose the wood grain my plan is to dye it red then either clear coat over that or use tung oil as a finish thanks in advance.
MichaelGA
Re: Can you use alcohol based dyes over a tung oil finish ?
Postby MichaelGA » Tue Apr 18, 2017 6:31 am
You would have to sand down to the bare wood to dye your guitar. Those angelus leather dyes work great! Very strong colors!
Michael
SomeGuitarGuy
Postby SomeGuitarGuy » Tue Apr 18, 2017 6:41 am
would it be possible to remove the tung oil finish without sanding ?
MichaelGA
Postby MichaelGA » Tue Apr 18, 2017 7:42 am
I don't know. An internet search may reveal other methods.
Postby skully13a » Tue Apr 18, 2017 11:20 am
Sanding is really the only way. It doesn't penetrate deeply, though.
SomeGuitarGuy
Postby SomeGuitarGuy » Wed Apr 19, 2017 7:15 am
yea i think iv changed my mind about dyeing the hole neck ill be just be dyeing the top of the headstock instead to match the body that it will be going on
Postby ilyti » Wed Apr 19, 2017 2:19 pm
SomeGuitarGuy wrote:yea i think iv changed my mind about dyeing the hole neck ill be just be dyeing the top of the headstock instead to match the body that it will be going on
Good call. But just to let you know, sanding the tung oil off the whole neck wouldn't take you long at all. Start with ~80 grit to get the finish off, then maybe 150 and finish up with something in the 300 range to smooth it back up and you should be done in 30 minutes. Then you can apply whatever finish you want. With painted gloss necks there's so much more stuff to get through.
