Brian Johnston Songs
- Brian Johnston
- Platinum Member
Eastern Sun
Instrumental... playing a Kiesel Vader... plugged into the Le Lead Preamp... into the Carl Martin Rock Bug (using the Carl Martin Red Repeat for delay):
https://www.reverbnation.com/grandfusio ... astern-sun
- Brian Johnston
- Platinum Member
- Brian Johnston
- Platinum Member
RiffRaff
A short rock instrumental using the Greg Howe Lick Box and a Kiesel VM7 guitar:
https://www.reverbnation.com/grandfusio ... 4-riffraff
- Brian Johnston
- Platinum Member
- Brian Johnston
- Platinum Member
Summer Surf
An instrumental I put together using the Surf Trem by Carl Martin:
https://www.reverbnation.com/grandfusio ... ummer-surf
- Brian Johnston
- Platinum Member
So Long, and Thanks for All the Fish
Instrumental using the Red Scorpion 2 distortion pedal:
https://www.reverbnation.com/grandfusio ... 25-so-long
- Brian Johnston
- Platinum Member
Tropical Chill
A brief instrumental using the Kiesel Vader VM7 and the Surf Trem (tremolo) with Red Repeat (delay), going through the clean channel on the Le Lead Preamp:
https://www.reverbnation.com/grandfusio ... ical-chill
- Brian Johnston
- Platinum Member
Suddenly
A new instrumental using my new Maple Leaf Royal Drive:
https://www.reverbnation.com/grandfusio ... 9-suddenly
- Brian Johnston
- Platinum Member
- Brian Johnston
- Platinum Member
Air (with Rockaway Archer pedal)
Playing around with various EQs and Gains on the Rockaway Archer (Rockett Pedals):
https://www.reverbnation.com/grandfusio ... 923593-air
- Brian Johnston
- Platinum Member
Pound of Feathers
Instrumental using the JCM800 pedal (Mystere) by Doc Music Station:
https://www.reverbnation.com/grandfusio ... f-feathers
- Brian Johnston
- Platinum Member
- Brian Johnston
- Platinum Member
Lone Son
Adding some high-gain to some Country type tracks (although it gets heavier in a few spots). Using Band-in-a-Box http://www.pgmusic.ca for the backing tracks and sounds.
https://www.reverbnation.com/grandfusio ... 8-lone-son
- Brian Johnston
- Platinum Member
- Brian Johnston
- Platinum Member
- Brian Johnston
- Platinum Member
- Brian Johnston
- Platinum Member
Infusion
Two hours to kill and I thought I would compose something of a modern tone mixed with some Latin cha-cha type backing tracks. Guitar is a Kiesel Vader. I have a Maple Leaf Royal Drive going into a Red Scorpion distortion. The Maple Leaf gain is only up at 9-o'clock, whereas the Red Scorpion is on, but the gain turned all the way down. The Red Scorpion adds some grit in the mix. Those two are running through a clean amp channel (Le Lead preamp) and into the Carl Martin Rock Bug (amp/cab sim pedal). Any harmony is via the Quintessence pedal (I added a 5th in a small dose).
https://www.reverbnation.com/grandfusio ... 32-infused
- Brian Johnston
- Platinum Member
Crosshairs
A 1.5 hour composition and jam (I gave myself that much time to develop and record). Nothing fancy, but it's fun to riff things out now and again. Using a Vader VM7 through the gain channel of the Le Lead preamp.
https://www.reverbnation.com/grandfusio ... crosshairs
- Brian Johnston
- Platinum Member
I Love the Way You Love Me
Originally had vocals and words, but my singing leaves a bit to be desired. It became a short instrumental:
https://www.reverbnation.com/grandfusio ... ou-love-me
- Brian Johnston
- Platinum Member
Simple Promise
An instrumental combining dirt. I took a high-gain channel on the Le Lead preamp, which not only sounds modern, but a touch sterile (good to my ears, but you know what I mean). I added the Vintage Fuzz II (model 2 SA 202) with germanium transistors. I kept the Bias somewhat smooth (a hint of breaking up) and the Fuzz at about 11-o'clock. It produced some great harmonics, bites and a different dimension to the tone.
https://www.reverbnation.com/grandfusio ... le-promise
Playing a Kiesel Vader VM7
