Instrumental Rock with Carvin DC
JackRose
Postby JackRose » Sun Sep 20, 2015 2:05 am
Hi Guys,
Purchased a DC127 this year, never had any Carvin guitars before. One word: fantastic!
Was already workin on my first instrumental and finally decided, to record the most of the song with this superb instrument!
Check it out if you have 4 spare minutes. :)
https://www.youtube.com/watch?v=QgBYO_ZplMw
JackRose
re: Instrumental Rock with Carvin DC
Postby JackRose » Sun Sep 20, 2015 2:08 am
Also would like to buy a lefty Carvin with H-S-S config, but neckthroug not bolt-on.
Are there any models with these specs?
Also would like to ask about lefty modells with piezo, which of them were equiped with piezo?
Thanks
Postby arahobob » Sun Sep 20, 2015 6:20 am
Welcome!
Piezo is an option on a bunch of models (just about any can be lefty). Comes on HH guitars.
Also available on Floyds. Its one of the first options in the builder.
HSS is definitely possible on neck throughs with some exceptions.
I can't remember seeing a dc600 HSS but I could be wrong.
I know someone just got a scb6 HSS.
Your best bet is to call and ask
Re: re: Instrumental Rock with Carvin DC
Postby spudmunkey » Sun Sep 20, 2015 9:07 am
arahobob wrote: Its one of the first options in the builder.
It depends.
If it is a model that uses the piezo add-on to the active electronics module that uses 4 knobs, and 3 mini switches, then it is on the first page where you select your bridge.
If it is a model that uses the newer piezo system that just has the one additional knob and one additional mini switch, the it is on the pickup selection page, near the end.
Postby Catman10 » Sun Sep 20, 2015 9:44 am
Very nice job! Cute tag at the end.
JackRose
Postby JackRose » Sun Sep 20, 2015 11:00 am
Catman10 wrote:Very nice job! Cute tag at the end.
Thanks 8)
JackRose
Postby JackRose » Sun Sep 20, 2015 11:01 am
arahobob wrote:Welcome!
Thanks for the answer!
JackRose
Postby JackRose » Sun Sep 20, 2015 11:02 am
It depends.
Cool, thanks, I'll check the builder page.
JackRose
Re: Instrumental Rock with Carvin DC
Postby JackRose » Sat Nov 26, 2016 7:43 am
And an other track with the trusty DC 127, all guitars were recorded with her.
Played mainly with the bridge pup, but also used the neck and the neck coil tapped for clean tones.
https://www.youtube.com/watch?v=SiSW2LuaA6U
rynnce
Postby rynnce » Sun Nov 27, 2016 10:24 am
Nice stuff! Enjoyed both songs.
Rob
JackRose
Postby JackRose » Sun Nov 27, 2016 12:39 pm
rynnce wrote:Nice stuff! Enjoyed both songs.
Rob
Thanks!:)
Postby Casual Madman » Sun Nov 27, 2016 1:39 pm
First time I've seen an UDAB player using sweep techniques - impressive. :applause:
JackRose
Postby JackRose » Tue Nov 29, 2016 11:43 am
Casual Madman wrote:First time I've seen an UDAB player using sweep techniques - impressive. :applause:
Thnx very much!:)
