Kiesel string spacing vs other companies
Moderators: Kevio, ElfDude, JesseM, ChrisH, peb, Mike Jones, Bundy, RockCrue, soundchick, Albert C
Benzene
Postby Benzene » Thu Oct 22, 2020 6:59 am
I'd like to know if the string spacing on all Kiesel's is the same. I am looking to get rid of my PRS SE SVN as the string spacing is a bit too much for my liking. Is the spacing on the Theos the same as the Aries and the Delos? I just picked 3 cool models I liked at random for examples. Thanks.
helldorado
Re: Kiesel string spacing vs other companies
Postby helldorado » Thu Oct 22, 2020 11:02 am
Kiesel's string spacing is based on the bridge you choose. So if you go with the 6 string Hipshot fixed bridge, string spacing will be the same 52.8mm regardless of the guitar model you're putting it on. Kiesel uses all third party manufacturers for their bridges so the info is available on the respective manufacturers website.
Most every bridge should be F-spaced except for the TOM.
