Carvin /X KIESEL TUNERS
farmin542
Postby farmin542 » Mon Jun 12, 2017 6:30 am
I'm going to give a ct6 from 2006 a makeover and want to change out hardware color. Can anyone tell me if the Kiesel branded locking tuners are a direct replacement for the Carvin branded locking tuners? Thanks.
Re: Carvin /X KIESEL TUNERS
Postby spudmunkey » Mon Jun 12, 2017 9:13 am
You have a 2006 with Carvin branded *locking* tuners? I don't think i know how that's possible. :shock: In 2006, they came with Sperzel, years before Carving came out with their Carvin-branded locking tuners.
farmin542
Postby farmin542 » Mon Jun 12, 2017 10:06 am
Body from 2006. Neck was replaced after the Kiesel conversion and entire guitar refinished by Jeff. As you can see it still has Carvin locking tuners on it. I have no way of making sure the Kiesel branded tuners are a drop in replacement except the hope that someone else has tried to do the same thing
Postby spudmunkey » Mon Jun 12, 2017 10:15 am
Oh, gotcha...ok, that makes more sense. A 2006..with new neck and tuners. :)
Postby Doctor Doug » Mon Jun 12, 2017 12:22 pm
I don't have an answer to your question but I had to say that that is a stunning guitar!
Postby arahobob » Mon Jun 12, 2017 3:48 pm
A few questions:
Why change the tuners? Aren't they the same, or is there a different ratio on the new ones?
How does one replace a neck on a set neck guitar?
Sounds difficult.
How does one get Kiesel to refinish a guitar?
I've asked, and been told flat out - no way.
Sounds equally difficult!
farmin542
Postby farmin542 » Mon Jun 12, 2017 6:59 pm
I've grown tired of the gold hardware. I put custom brass block and brass trem stopper on to make Floyd fixed as well and I'm switching saddles to chrome string through saddles so I don't have to cut strings anymore, then changing to chrome nut, chrome tuners, new CTS mini pots, speed knobs, and Suhr Pete Thorn pickups. The tuners work fine as do the pots, knobs, and pickups, just morphing it into something else for fun. I have another one with same build specs including the gold hardware but differant finish. Also they won't refinish as a rule as far as I know, the neck failed in the 1st version so it was replaced and refinished the entire guitar. And no it is not easy compared to swapping out a bolt on neck, but very doable by skilled luthiers.
farmin542
Postby farmin542 » Mon Jun 12, 2017 7:39 pm
Doctor Doug wrote:I don't have an answer to your question but I had to say that that is a stunning guitar!
Thank you sir!
farmin542
Postby farmin542 » Tue Jun 20, 2017 9:03 am
I got a reply from Kiesel and the tuners are same specs as the Carvin tuners.
