Mini toggle Classic Bolt?
rykrsbeard
Postby rykrsbeard » Mon Dec 11, 2017 7:50 am
Hey all!
Just a quick question about my new Classic Bolt. It’s an HSS configuration, and I wanted to be sure about the function of the mini toggle under the tone knob. It seems to me that if the toggle is “up” (pointing at the pickups) the humbucker is on, and if it’s “down” (pointing at the floor) it’s functioning as a single coil.
Do I have this correct?
Re: Mini toggle Classic Bolt?
Postby Doctor Turn » Mon Dec 11, 2017 8:13 am
I believe that switch gets you the Tele style 2 pup position of 1 and 3, bridge and neck together. I'd wager that it's full humbucker though I could be wrong.
rykrsbeard
Postby rykrsbeard » Mon Dec 11, 2017 10:00 am
I’m not certain that’s the way it works in my Bolt.
I’ve seen posts suggesting that you can have the toggle wired to combine pickups, but I understand that to be a special order and the toggle does not seem to affect the sound in any other position on the five way blade selector other than the bridge position.
Postby Doctor Turn » Mon Dec 11, 2017 10:15 am
Ah, here's your answer (pays to google, which I just did for you-- "Carvin Bolt Mini Switch," which took me to this thread)
With an SSS guitar the mini is an "always-on" switch for the bridge pup. So if it's on and you use the 5 way to select neck only or neck + middle, the bridge is added to the mix.
On HSS Bolts that same switch is just a coil splitter.
So there ya go.
rykrsbeard
Postby rykrsbeard » Mon Dec 11, 2017 11:24 am
Your Google-fu is stronger than mine. I couldn’t find any relevant info.
BTW, could you repost the link in your thread? For some reason, clicking the link you provided loops back to this thread.
Postby spudmunkey » Mon Dec 11, 2017 11:29 am
rykrsbeard
Postby rykrsbeard » Mon Dec 11, 2017 11:54 am
Thanks. That did the trick. :D
Unfortunately, that still leaves my original question—is “up” the full humbucker? Sounds like it.....
Postby Doctor Turn » Mon Dec 11, 2017 12:16 pm
LOL--thanks Spud.. I've got like 5 things going at once at work and wasn't paying attention and grabbed the wrong window's URL. But that was the thread, of course.
Postby Doctor Turn » Mon Dec 11, 2017 12:17 pm
BTW my search was "Kiesel Bolt Mini Switch"
https://www.google.com/search?q=kiesel+ ... e&ie=UTF-8
Postby wickid » Mon Dec 11, 2017 12:43 pm
rykrsbeard wrote:Thanks. That did the trick. :D
Yes. Typically, "up" = normal operation (ex full HB), down = "effect engaged" (ex coil split, or phase, always-on, etc).
rykrsbeard
Postby rykrsbeard » Mon Dec 11, 2017 1:07 pm
