Spalted Crescent & Vintage TL60
Expecting some new gear from Kiesel Guitars? Post here!
Postby JCG » Wed Sep 27, 2017 2:09 pm
Here are the specs:
TL60 GUITAR CLASSIC FIXED BRDGE
BV ADD BEVELS
VC VINTAGE CREAM
IOD OFFSET DOT INLAYS
IMP MOP INLAYS
STJF STAINLESS STEEL JUMBO FRETS
135 - C22B Bridge Humbucker/2 S60A Pickups & 5-Way Switch
HSS Neck/Center Singles Hum Bridge
TBH TWINBLADE P/U OPTION
34 PUSH PULL TONE COIL SPLIT
PUSH/PULL SPLIT NECK & MID ONLY. MINI SWITCH SPLIT
BRIDGE ONLY.
31 ONE COIL SPLITTING SWITCH
PDM PICKUPS DIRECTLY MOUNTED
BC BLACK CHROME PLATED HARDWARE
BL BLACK LOGO
SL STRAPLOCKS BY DUNLOP
ETR L2: JCG
SC10 ULTIMATE SOFT GUITAR CASE
*Mark and Jeff to sign*
CRESCENT 6 FLOYD
LN FLOYD LOCKING NUT
SWT SPECIAL WOOD TOP - SEE JEFF
50 SPALTED MAPLE BODY
1 piece spalt body&top from same piece. FINISH.
TY>TR>trans black burst>trans red painted binding.
3PB 3 PIECE LAMINATED BODY
CMB CHAMBERED BODY
51 CRESCENT C HOLE
/GD TR PAINTED BINDING
TY VINTAGE YELLOW
TR CRIMSON RED
RMT REAR MATCHES TOP COLOR
TN TUNG OIL FINISH BACK OF NECK
H33 POINTED 3+3 HEADSTOCK
SMPH SPALTED MAPLE HEADSTOCK
REF ROYAL EBONY FRETBOARD
ISOD STAGGERED OFFSET DOT INLAY
IAR ACRYLIC RED INLAYS
EVOJ EVO JUMBO GOLD FRETS
R14 14" fretboard radius
22B INSTALL C22B BRIDGE P/U
FG22 Gambale Neck
DSLB DROP SHADOW LOGO BLACK
TCE EBONY TRUSS ROD COVER - JEFF TO SIGN
Re: Spalted Crescent & Vintage TL60
Postby spudmunkey » Wed Sep 27, 2017 2:33 pm
Ooh...are the Crescent bodies thin enough that they can do that? I believe the CT or CS was too thick to do that with some woods.
Looking forward to the beveled TL in VC, though, too! :applause:
Postby JCG » Wed Sep 27, 2017 2:54 pm
spudmunkey wrote:Ooh...are the Crescent bodies thin enough that they can do that?
I had ask if the piece of wood that Jeff wanted to use was thick enough to do a Crescent and was told that it was.
Postby JCG » Wed Nov 22, 2017 11:05 am
Some pics of the Crescent from today's live feed:
Jeff hooked me up with a thick flamed maple layer for the 3pb. :D
Postby dejabluguitar » Sat Nov 25, 2017 10:48 am
this thing is unbelievable. then the op51 amongst all the dark spalted bits. I so want to see this.
this baby is a long time coming! like 11monthes now. Good thing they whipped out some other builds for you in the mean time.
Postby arahobob » Sat Nov 25, 2017 6:20 pm
What's the board on the tl60?
Postby JCG » Sun Nov 26, 2017 4:25 am
arahobob wrote:What's the board on the tl60?
Ebony.
Postby arahobob » Sun Nov 26, 2017 5:56 am
Ebony.
That's sounds great!
Postby JCG » Tue Nov 28, 2017 2:02 pm
Postby JCG » Wed Dec 20, 2017 11:26 am
Return to The Waiting Room
