Primer Grey SCBM6 w/Thorium
Expecting some new gear from Kiesel Guitars? Post here!
Postby JCG » Fri Jul 13, 2018 4:36 am
Ordered 7-12-18
SCBM6
R - Right Handed
MA - Maple Neck/Alder Body (Standard)
CG - Clear Gloss Finish (Standard)
50 - Primer Grey
PTC - Pearl Top Coat
6INR - Pointed Straight 6 Inline Reverse Headstock
PH - Headstock To Match Body Finish (Standard)
BMF - Birdseye Maple Fingerboard (Tung-Oiled)
ISOD - Offset Dot Inlays (Staggered)
IAB - Black Acrylic Inlay Material
STJF - Stainless Jumbo Frets
R20 - 20in Fretboard Radius (Standard)
NPD - No Neck Pickup (Bridge Pickup Only)
50 - Kiesel Thorium Bridge Pickup
PPB - Black Pickup Poles
404 - White Coils
CHR - Chrome Hardware (Standard)
DSLW - Drop Shadow Logo White on Black
PK - Metal Knobs w/ White Pearl Inlays
SL - Dunlop Straplocks
WPB - White Pearloid Tuner Buttons
46 - Elixir 1046E Light Gauge Strings
SC10 - Black Ultimate Soft Guitar Case
Notes: pull-up volume/kill switch,
delete tone knob & 5-way pickup selector.
Re: Primer Grey SCBM6 w/Thorium
Postby spudmunkey » Fri Jul 13, 2018 7:54 am
That thing's going to be brutal. :applause:
Gloss neck?
Are their other pearl finishes derived from a pearl topcoat? I don't believe i've ever seen that option separated out like that before. :think:
Postby JCG » Fri Jul 13, 2018 8:18 am
spudmunkey wrote:That thing's going to be brutal. :applause:
Gloss neck?
Yes to the gloss neck.
As far as I know, the PTC has only been used on the JBPB and over classic white.
I had inquired about doing the PTC over the Primer Grey back on 4/5/18 and
I was also told that by the look on Jeff's face when asked about this, that he had not thought about
using the PTC over other colors.
Postby dejabluguitar » Fri Jul 13, 2018 3:40 pm
maybe later paint the pearloid tuners white, to matck the other white elements more closely. do you expect the PTC to have a dramatic effect?
Postby JCG » Fri Jul 13, 2018 4:15 pm
dejabluguitar wrote:do you expect the PTC to have a dramatic effect?
No, I think it will be subtle, but give some life to a otherwise flat color.
relias7505
Postby relias7505 » Sat Jul 14, 2018 9:58 am
Post a video of that Thoruim pickup when you get the guitar! I would love to see if it holds a candle to the M22SD
My Kiesel/Carvin collection: ST300 (M22SD bridge, S60A middle, Twin Blade neck), SCB6 (S22B bridge, S22J neck), Bolt Classic (AP11's in all positions), SH550 (S22T in the neck and bridge), AC375 and CL450. Also a Carvin V3M 50watt head with a Carvin 1x12 cabinet and Fender Jazz Bass.
Return to The Waiting Room
