Zeus Tuning
kimbass
Zeus Tuning
Postby kimbass » Sun Sep 16, 2018 4:48 pm
Hi -- I have a Zeus bass, and am having trouble changing the strings due to not being able to make the claws (that hold the ball-ends) move forward towards the nut: the tuning barrel just loosens, and the claws are already too far back to do the job correctly. Any suggestions on how to correct this?
Thanks
Re: Zeus Tuning
Postby HarlowTheFish » Sun Sep 16, 2018 4:52 pm
kimbass wrote:Hi -- I have a Zeus bass, and am having trouble changing the strings due to not being able to make the claws (that hold the ball-ends) move forward towards the nut: the tuning barrel just loosens, and the claws are already too far back to do the job correctly. Any suggestions on how to correct this?
Thanks
If you unscrew it as far as it will go, then pull it back and keep going a little more, it screws into itself in an extended position, so you can hold it forward. That's how it is on my (guitar) system, should be the same on the bass version. It's still a little awkward, though, so I recommend using a small screwdriver through the ball end to position it and a second one to push it into place.
kimbass
Re: Zeus Tuning
Postby kimbass » Sun Sep 16, 2018 5:00 pm
Thanks for your quick response. I actually tried that earlier, but it didn't work... maybe the larger bass system entails more friction, making it harder to get a sufficient grip. Might try Loc-tite or something like that. Right now one claw is all the way back, so I can't really get anything in there... looks like getting a strong connection between the barrel and screw would be the answer, but any additional insight would be welcome.
Re: Zeus Tuning
Postby spudmunkey » Sun Sep 16, 2018 5:08 pm
Does this help at all?
https://youtu.be/lEIS4cx852k
kimbass
Re: Zeus Tuning
Postby kimbass » Sun Sep 16, 2018 5:41 pm
Thanks, it did.
