Osiris 7string pick-up
PJCruz
Postby PJCruz » Fri Nov 29, 2019 9:56 am
Hello All! Hope everyone had a great Thanksgiving.
I’m giving some serious consideration to installing some active pickups into my 7string Osiris.
I was curious if anyone had changed their pickups and had any trouble with the pickups not fitting. I know I’ll have to “shave” the square mounting tabs to fit in my axe but not sure on the other dimensions..
Haven’t decided but it’s between the Fishman Fluence or EMG 57/66-7.
I currently have the stock 7string Lithium’s in there now.
Thanks
Re: Osiris 7string pick-up
Postby HarlowTheFish » Fri Nov 29, 2019 4:03 pm
On the EMG side I'm more of a 60AX bridge/60X neck (or the non-X variants at 18 volts). I'm much more of a fan of the Fishman Tosin Abasi set than basically any other active pickup though, because it's super versatile and sounds really nice throughout the full range of the guitar.
The only issues you might have are with the battery fitting, but in an Osiris you should have room.
