Replacing active routed 2012 Carvin with passive pickups?
Hybrid138
Postby Hybrid138 » Mon Mar 23, 2015 5:10 pm
I bought a Carvin from 2012 and it has the active pickups in it. Will passives fit? I know I can get after market pickup rings but will the screws line up? Anything else I need to consider before buying some passives?
My Ska/Progressive Band http://www.facebook.com/blisstx
re: Replacing active routed 2012 Carvin with passive pickups
Postby spudmunkey » Mon Mar 23, 2015 5:16 pm
What model do you have? :think:
I ask because Carvin's active pickups (The A60, A70 and A80) have all been direct-mounted with no rings, as far as I know (like the DC600)...so no ring holes to line up.
Is it, perhaps, the active pre-amp with the passive pickups? (like the DC127, DC400, TL60, etc)?
Hybrid138
Postby Hybrid138 » Mon Mar 23, 2015 6:04 pm
Sorry forgot to mention the model. It's a DC700. They are direct mounted active pickups with the battery spot in the back of the guitar.
potatohead
Postby potatohead » Mon Mar 23, 2015 7:20 pm
You'll need active sized passives, or pickup conversion rings.
V3M 212
2012 DC700 (gloss spalt)
2013 CS6 x 2 (satin purple flame, satin green flame)
2013 CS4 (satin black)
2015 CT4 (satin blue ash w/ AAT)
Hybrid138
Postby Hybrid138 » Mon Mar 23, 2015 7:55 pm
If I used pickup conversion rings, can I use the existing screw holes for the new pickups or will I need to drill new ones?
Postby spudmunkey » Mon Mar 23, 2015 8:04 pm
fretsonthenet sells these and it looks like you'll need 4 holes in the corners.
