Okay to use Carvin tuners without the thumb lock?
oreos
Postby oreos » Tue Mar 21, 2017 8:52 am
i recently bought a 2015 Carvin that came with locking tuners and a hardtail. i dont feel like the locking mechanism is necessary in this context. is there any reason not to just remove the locks? they seem like relatively nice open backs without them, but i cant tell if the locks have any structural or functional purpose in addition to locking
Re: Okay to use Carvin tuners without the thumb lock?
Postby wickid » Wed Mar 22, 2017 8:49 am
:?: :? :think:
Well, the posts usually only have enough space for 1 wrap or so. But why would you not lock the strings, regardless of bridge??
Postby Koshchei » Sun Mar 26, 2017 5:40 pm
I imagine they'd rattle if you left them unlocked.
Postby arahobob » Sun Mar 26, 2017 6:32 pm
I'd use the locks.
You have them.
Super easy string change.
Minimal slipping.
What would be the benefit of not using them?
tbonesullivan
Postby tbonesullivan » Wed Mar 29, 2017 8:32 am
IMHO, they will not really work without the thumb screw tightened. They are not really designed to be used like standard tuners, which would have tapered posts and a much smaller hole for the string to go through.
Kellameron
Postby Kellameron » Fri Jun 02, 2017 10:45 am
tbonesullivan wrote:IMHO, they will not really work without the thumb screw tightened. They are not really designed to be used like standard tuners...
Yeah. The technique is to pull the strings tight, then turn the thumb screw.
Less turns equals less slip, tighter tuning. I've always loved the Sperzels.
