Lithium Hex screw wrong length?
Bendit
Postby Bendit » Sun May 14, 2017 4:13 am
one hex screw of my lithium pickup is not completely screwed in. is there a reason for this, should i try to screw it in further?
the picture shows the neck pickup but the bridge-pu looks completely identical (also 1 screw aligned to the d-string).
i never messed with it, i received the guitar and the PUs like this from kiesel.
Re: Lithium Hex screw wrong length?
Postby arahobob » Sun May 14, 2017 5:04 am
They're all shipped like that I believe, and they're fully adjustable.
Do whatever you like - see how it sounds.
Postby texastoast » Thu May 18, 2017 7:53 pm
Short answer is perfectly normal and by design.
It is my understanding is that it is set in the factory to give balanced output for all strings. Same thing with the socket cap screws in the Carvin pickups. I have played with them in the past. I was never able to notice much of a difference with reasonable adjustments. I have never tried the kiesel pickups. Maybe more dramatic results.
Treadplatedual
Postby Treadplatedual » Tue Jun 06, 2017 12:00 pm
texastoast wrote:Short answer is perfectly normal and by design.
Exactly - just like moving the entire pickup closer to the strings increases output, the adjustability lets individual strings give more or less output based on what sound you're going for.
2017 SH6 - Piezo/S22s
