Rewiring a Vintage CM-140
Stargazer735
Postby Stargazer735 » Mon Oct 16, 2017 4:26 pm
Hi, all!
I'm trying to rewire a vintage CM-140 and I'm running into a bit of trouble.
I was able to find a wiring diagram (http://www.carvinmuseum.com/decade/images/77-cm140wiring.html) but the jacks have me a bit confused. It looks like there are 2 stereo output jacks, but one is labeled as mono... and yet, it has 3 prongs and 3 wire connections to it.
Curious - does anyone else have experience with these? Does this diagram need to be corrected, or is it just me?
Buckeye Burl/White Limba CS6 w/ Walnut/White Limba neck, Lithium Pickups
Black Limba'd Carvin DC127 w/ Graphtech Piezo Floyd Rose, M22SD & M22N Pickups
Spruce/Walnut AC375
SX300 100W 2X12 amp in Python Snakeskin
Avid astronomer, lover of stringed instruments and Led Zeppelin fanatic
greenghost1964
Re: Rewiring a Vintage CM-140
Postby greenghost1964 » Thu Nov 23, 2017 9:53 pm
I currently own 2 1983 CM 140's..........never had to re wire one.........the jacks are both mono.........or one is stereo the other (main) jack is mono...........if you are running mono, you use the one closest to the rear. Curious, what color is your CM140?? Thanks Wendell
greenghost1964
Postby greenghost1964 » Thu Nov 23, 2017 9:56 pm
PS: that diagram is for like 1981 or so and older, with only 3 knobs total too............82/83 had 4 knobs total, just saying
