Hipshot contour trem problem
Re: Hipshot contour trem problem
Postby UnexplodedCow » Wed Jan 10, 2018 1:03 pm
Glad this one ended well. Give things time to wear in, and I think you'll be quite happy with how stable the Contour can be.
PO0784
Postby PO0784 » Tue Jan 16, 2018 12:50 pm
Hey UnexplodedCow, since you are a user of this trem, does this particular situation happens to you a lot:
I tune the guitar perfectly and use it for like 1 2 hours...gotta retune between everysong or so (it gets +2..+3 sharps on some strings). Whenever I use the trem, I get sharp notes somehow... so I just finish the song and tune it back...
Then if I put it down and take it the next day... surprise! Every string is like +2 +3 sharp.
Still sounds like some binding at the nut right?
Postby UnexplodedCow » Tue Jan 16, 2018 2:00 pm
Yup. That is nut binding, and possibly string slack depending on how you wrap strings. My guitar has sperzels, and I have about .5 to .8 of a wrap on the post, so very little chance for slack. However, my guitars nut was originally cut for 9s, and I use 10s. I had binding in the nut, specifically with G and B strings until I took time to slightly enlarge the slots. That took care of the problem. The contour itself was never a problem. I had nut binding with the wilki, too, and then had knife edge problems, which led me to retrofitting the hipshot in. It's been about 3 years with it in. Best non locker I have ever had.
You may want to take your guitar to a Lucifer (thanks, autocorrect, I really mean luthier) and have them work the nut slots a tad, or if the guitar is still under warranty, Kiesel should do it. Or you can try to wear in the nut yourself if you're handy. Nut lube goes a long way, too (some use nut sauce, I use stuff from Daddario, others use Teflon powder or graphite). It's probably best to try lubing the nut first, and see what happens.
