ioneater wrote:It's hard for me to think of any cons. A clip-on tuner works just fine.
Hey! Curious as to what clip on tuner are you using. I have a small D'Addario Planet Waves NS Micro Headstock Tuner but that won't stay in place.
Vader guitar... pros and cons.Moderators: Kevio, ElfDude, JesseM, RockCrue, soundchick, ChrisH, peb, Mike Jones, Bundy
Re: Vader guitar... pros and cons.
Hey! Curious as to what clip on tuner are you using. I have a small D'Addario Planet Waves NS Micro Headstock Tuner but that won't stay in place. Thanks!
Intellitouch. https://www.sweetwater.com/store/detail ... 3qEALw_wcB
Re: Vader guitar... pros and cons.Ioneater! Happy New year to you! Haven't seen you around lately. Hope all is well. I know you were dealing with an injury to your shoulder there for a bit (I think it was your shoulder, anyway). I hope you're cranking on all of those V's and that nice Nineties koa neck thru.
1985 DC150K (koa) Stereo, M22N/M22SD w/black hardware. 1985 100 Watt X Amp 2 x 12 combo (XV212) upgraded w/ 2 Vintage 30's ...and other gear. https://soundcloud.com/the_heavy_clouds
Re: Vader guitar... pros and cons.Polytune2.
Re: Vader guitar... pros and cons.Only one con......
No hardshell case. Other than that.... perfect.
Honestly, I like the soft case better!! And I used to be a hard line hard case guy!
Oops, missed your post until tonight, Doc. And....happy new year to you as well ![]() You do not have the required permissions to view the files attached to this post.
Re: Vader guitar... pros and cons.Pro: Sounds Great!
Con: Ugliest guitar on Earth (I never claimed to have good taste!) 2015 SCB6M WW, BC, 404, PSN, SL
2013 Bolt Plus Ash1, TR, RW, S22s, 2007 TL60 133, B, MP, TN 2004 TL60t FTS, BB, 127, AB, TN, MAH, FPH, 402 MTS 3212 BR12's Vintage 16 Celestion V30
Re: Vader guitar... pros and cons.Actually, I think the Vader is a great looking guitar. Everyone I have shown mine to has been very impressed. My VM8 is the most light and compact and comfortable 8 string I have every played. I think access to the headless tuners is the best of all the Kiesel designs.
My only issue has been transitioning to an 8 string. While it brings new possibilities, it also brings more complexity. I go back and forth. When I get overwhelmed by the 8, I go back to a 6. Then the 6 feels like a tooth pick and I fall into my usual playing ruts. Then I pull out the 8 and rediscover how great it is. Currently, I am back playing the 8 and experimenting with different tuning's. It has really expanded my fretboard knowledge and inspired me to create new musical ideas I never would have thought to do on a 6. Exciting stuff. I am having a great time.
Re: Vader guitar... pros and cons.Can you put heavy gauge strings on a headless guitar? I've heard that you aren't supposed to, but I don't really know. I'm thinking of buying a Holdsworth headless, but it'd be a deal breaker if I can't put 12s on it. What do you guys think?
Re: Vader guitar... pros and cons.I have 11s on mine, with no issues. Truss rod is not even that tight. I did send the strings in so it could be set up with them from the start.
Thank you for your reply! Do the strings fit easily into the holes at the bridge and at the nut? One concern I have is that the 12s would be physically too thick to fit through those holes.
Re: Vader guitar... pros and cons.No problems stringing up with 11-49, so I think you'd be fine with 12s. Again, best to call in when you order to indicate you want the guitar set up with that particular set of strings.
Okay! I definitely will call in about that. Thank you!
Re: Vader guitar... pros and cons.Also, do you think a 56 would fit on the low end? How tight is it on the 49? I use 12-56
My v7 uses a 60 or 62. You'll be fine. Current Carvins:
2010 Bolt (Candy Red Metallic) 2013 Bolt Plus (Koa) 2016 Black n Blue VSEVEN 2017 TT SCB6 Wish List Some sort of multiscale 6 HSS with RAD ASH JB Numbers Guitar (July sale has given me the itch!)
Thank you, I appreciate that! The slot for that one isn't bigger because it's a 7 string?
On the nut, I'd assume so. I was just referring to the hardware - i'll give it a look over when I change strings to investigate. Current Carvins:
Re: Vader guitar... pros and cons.Recent Vader CON:
After playing the V7 with my electric gig for the last month or so, ALL of my regular guitars feel HEAVY!!!!!! ![]() Current Carvins:
Yep Return to Kiesel Guitars / Carvin Guitars Who is onlineUsers browsing this forum: No registered users and 16 guests |
The views and opinions expressed on the Kiesel Guitars BBS are solely the responsibility of the authors, and do not necessarily reflect
the opinion of Kiesel Guitars / Carvin Guitars. The KieselGuitarsBBS.com administrators will block all e-mail addresses violating the established BBS rules.
Topics that are not based on Kiesel Guitars / Carvin Guitars gear or experiences with Kiesel Guitars gear may be subject to deletion.
