LB70 Club
AzBloozBase
re: LB70 Club
Postby AzBloozBase » Sun Jun 07, 2015 7:28 pm
Ok all... here she isImage
LB75PJoe
Re: LB70 Club
Postby LB75PJoe » Sat Feb 10, 2018 7:24 pm
Update: Albert from Tech Support told me the active passive module from their kits would work without the Piezo. Turns out the pots don't all line up and I have a dummy pot in temporarily but the module still doesn't seem to work right. The mid and treb have zero effect and the bass seems to act more like a tone control than a cut or boost. I've removed and de-gunked the battery boxes but I think I am going to re-wire the module and battery boxes as my first soldering attempt is suspect.
This is before the repairs made to the LB75p
Hello fellow LBers. I am new to the forum but have owned an LB70p since 2009 and recently acquired a LB75p. Pictures will be coming shortly but I have a question: has anyone ever removed a battery (both basses are 18v) WITHOUT unplugging the bass? I did this past week on my LB75 and now the only way I get any output is on the "up/passive" mode. Am I screwed? Are there parts that I can change or aftermarket pre amps that will fit?
Praiser
Re: LB70 Club
Postby Praiser » Sun Feb 11, 2018 5:21 am
I've never done it, but many have, so don't feel too bad.
This is a known issue that the preamp blows if the battery is removed with the cable plugged in.
I'd recommend calling the factory to see if they still have any of the older preamps available.
You'll need to open the cavity and either take a pic or find the number printed on one of the circuit boards.
Alternately, I think the new 4 knob pre will fit into the older cavity as it has some flexibility, but I'm NOT certain.
You'll likely have an extra hole or 2 though. Getting the piezo in the bridge to work is the big challenge
Some folks just leave them passive and use just the volume and blend as they still sound great.
Me personally, I'd try to get a Carvin/Kiesel unit to put in there, but there are aftermarket pres that would work, too.
Again, the piezo is going to be the challenge....
One guy that had major electronics skills was able to repair his and add a circuit to prevent it from happening again.
No idea if that thread is still around as it was a few years back, but search here and at the CarvinMuseum website.
Best of luck, and let us know how it works out for you....and we really need pics of these basses. :wink:
John
XP1000L, LM153s, LS1801A
Peavey Fury P Bass
Re: LB70 Club
Postby gumbynotpokey » Sun Feb 11, 2018 11:53 am
Praiser wrote:I've never done it, but many have, so don't feel too bad.
what he said
hi john!
LB75PJoe
Re: LB70 Club
Postby LB75PJoe » Mon Sep 10, 2018 6:51 am
Hey All...
I've had a friend go in and clean up my install mess... I suck with a soldering iron, not bad with a 9-iron, but suck with a soldering iron and still no tonal difference when in active mode from the treb and mid pots. The bass pot acts more like a tone control than anything else. I am comparing this to the functioning pre amp on my 4-string LB. The replacement is the 501 non piezo module sothe pots are arrange bass - treb - mid instead of the bass - mid - treb.
Is there any chance the module could be bad? My guy only wired it for 9-volt cause he read the 18-volters were more problematic on the 501 module. Any thoughts? I am tempted to ship it back to Carvin/Albert and let them go thru it for me at this point...
Joe
Re: LB70 Club
Postby ElfDude » Mon Sep 10, 2018 9:20 am
Does LB76 count for this club?
