New Vader Series Headless Basses
Announcements from Kiesel Guitars & the Forum Administrator
Moderators: Kevio, ElfDude, JesseM, ChrisH, Mike Jones
Kevio
Forum Admin & Kiesel Guitars Webmaster
Postby Kevio » Sun Nov 01, 2015 5:23 am
You asked for it, you got it!
The new Kiesel Vader Series headless basses feature an aggressive, compact beveled body, which provide modern looks with comfortable playing. Generous forearm and belly cuts further add to the satisfying ergonomics of the bass. A sculpted lower cutaway further accentuates the styling of the instrument, while allowing easy access high on the 24-fret, 34" scale fingerboard, and a 30" short-scale option is offered on all three models. Our chambered body option further reduces the already light weight of the instrument. The standard body wood is alder, with an Eastern hard rock maple neck-through design. Dual modulus carbon-fiber rods, along with a 2-way fully adjustable truss rod make the neck remarkably stable, and allows you to adjust the action exactly the way you want it, regardless of your playing style.
Other features of the Vader Series basses include a standard Hipshotâ„¢ bridge with exclusive Kiesel locking nut/headpiece assembly, allowing the use of standard bass strings. Radiused-top RADHV humbuckers are standard, with passive electronics and a master volume, master tone and pickup blend controls. Radiused single coil pickups and active electronics are also available. Hundreds of Custom Shop options, including body and neck woods, top woods, fingerboard woods, fretwire, inlays and much more allow you to design your new Vader bass exactly the way you want it. Like all Kiesel and Carvin Guitars, the Vader Series is proudly made in the USA at our southern California facility.
Right here: http://www.carvinguitars.com/vaderbass
The gear:
DC6, HH2X, V440, CT6T, V220C, IC4, IC5P, BB70P, XB75, AC40, LB70K, LB70, LB70, LB70F, XB76WPF, SB40, MB1, DN640K, DN440T, AC375
Return to Announcements
