Skully's Bolt Kit Thread
Postby skully13a » Fri Nov 20, 2015 11:07 am
Howdy. .... :D this will be my build thread, displaying my progress, or lack thereof.
So now, let's get to it!
The kit!
The neck!
It starts boring, but should improve in time.
re: Skully's Bolt Kit Thread
Postby Doctor Doug » Fri Nov 20, 2015 1:08 pm
I'm excited already! Not enough of these threads!
kennym9898
Re: re: Skully's Bolt Kit Thread
Postby kennym9898 » Fri Nov 20, 2015 5:29 pm
Doctor Doug wrote:I'm excited already! Not enough of these threads!
Same here, It's actually surprising how little kits are actually on the BBS. I'd think there would be a lot more posted.
I'm interest in seeing it. I still want to do one but I keep putting it off now in hope for a 24 fret bolt kit.
Postby skully13a » Sat Nov 21, 2015 8:27 pm
Well, I started with the neck. ...sanded to 800. So far, so good...whoa, that's becoming like my mantra. :lol: .That maple sands out nice......
The plan is to tung oil the back, paint the front of the headstock. More later, as progress is made....it'll be in fits & starts, as I'm in the Oil Patch now, at work. Stupid job.
Also sanding out the body so I can fill the grain & sand it again. :roll: meh.
Postby skully13a » Mon Nov 23, 2015 1:38 pm
Got the headstock primed & ready for some color! Probably be a couple days, though...we'll see.
Body is sanded & grainfilled.
Bonehead edit: Here's another pic of the body after grainfill but before priming....it's actually got some cool lines. Kind of a shame to cover it up but, there's already a process underway....press on!
Postby skully13a » Sun Nov 29, 2015 11:00 am
Sanding through is easy to do. ...meh. :oops:
Time for some touch ups..... :?Image
Postby Coda » Sun Nov 29, 2015 11:04 am
skully13a wrote:Sanding through is easy to do. ...meh. :oops:
Ouch! :o
But I like where you're going with the color! :D
Postby Doctor Doug » Sun Nov 29, 2015 4:50 pm
More pics!! :mrgreen:
Postby skully13a » Mon Nov 30, 2015 1:27 pm
Reshot the headstock.....it will keep for awhile, until I get a clear coat on it. Btw, that color is Crown Royal Purple.
Started priming the body!!
8)
Yeah, progress is slow, but then I work 6 day weeks, too. Meh.
Postby skully13a » Thu Dec 03, 2015 6:40 pm
Well....8 coats later. Headstock is ready to clearcoat.
Shot some paint on the body. ...it'll take a wee bit longer... :roll:
I'll even it up as I progress.
I actually blew it by sanding the color.....don't sand metallic colors. You'll be fixing it. Meh. Learning process for sure. :wall: :think:
Check it out....I put the secrecy shroud over it when I'm out working....hey, I'm working on this in a trucking shop
Postby Doctor Doug » Mon Dec 07, 2015 11:22 am
"Secrecy Shroud"! Love it!
Postby Coda » Mon Dec 07, 2015 1:22 pm
skully13a wrote:Check it out....I put the secrecy shroud over it when I'm out working....hey, I'm working on this in a trucking shop
Makes me curious what's hidden in the cloaking boot... :think:
Postby skully13a » Mon Dec 07, 2015 1:29 pm
I actually had to pull all my stuff out of there. Too hard to maintain a dust free, or mostly free space. It's North Dakota after all.....I'll try to make some progress over the next 5 weeks, and finish her up at home. I reckon I can finish the headstock in my shack, that way I can get the neck done. :x
MichaelGA
Postby MichaelGA » Mon Dec 07, 2015 4:59 pm
What kind of paint are you using, Polyurethane, acrylic, Laquer?
Michael
Postby skully13a » Mon Dec 07, 2015 6:14 pm
Nitro lacquer, man.
On that note, I got 3 coats of clear coat on the headstock, so I've got it gassing off, sanding tomorrow night. Then do it again......... :roll:
gjacob
Postby gjacob » Thu Dec 10, 2015 2:34 am
What are you using to fill the body (epoxy, ColorTone, Aqua Clear, etc)? In my experience sanding sealer and primer is not enough for a high-gloss finish and tend to lean towards Aqua Clear.
Gear:
'16 Kiesel CS6, '15 Kiesel DC600, '09 Carvin CT4, '78 Ibanez Musician, '95 Fender Am Strat, '98 Gibson Les Paul DC, '05 Schecter C-1 Hellraiser, '07 LTD EC-1000FM, '15 Gretsch G5422, Custom Strat, Custom Iceman, Custom Tele
Postby skully13a » Thu Dec 10, 2015 4:08 am
I used oil based grain fill from Reranch...3 coats....then 2 coats of sand seal, then 2 coats white primer....then the purple!
Still needs a couple clear coats......then polish forever.
gjacob
Postby gjacob » Thu Dec 10, 2015 8:35 pm
skully13a wrote:I used oil based grain fill from Reranch...3 coats....then 2 coats of sand seal, then 2 coats white primer....then the purple!
Still needs a couple clear coats....then polish forever.. :roll:
Looks awesome. That is one beautiful purple.
Gear:
Postby spudmunkey » Thu Dec 10, 2015 11:04 pm
That's a fantastic color!
Postby skully13a » Fri Dec 11, 2015 3:53 am
Thanks guys......yeah, I think it's pretty cool.Crown Royal Purple. It'll be even better once I get the pearloid pickguard on to set it off. It's a fun process, if a bit tedious. Pretty rewarding, though. :mrgreen:
