Brian Johnston Songs
Eastern Sun
Postby Brian Johnston » Fri May 25, 2018 10:35 am
Instrumental... playing a Kiesel Vader... plugged into the Le Lead Preamp... into the Carl Martin Rock Bug (using the Carl Martin Red Repeat for delay):
https://www.reverbnation.com/grandfusio ... astern-sun
Riffing with Carl Martin
Postby Brian Johnston » Wed May 30, 2018 3:58 am
A short riffy piece using some Carl Martin pedals:
https://www.youtube.com/watch?v=-jkaxFBBrSc
RiffRaff
Postby Brian Johnston » Thu May 31, 2018 12:33 pm
A short rock instrumental using the Greg Howe Lick Box and a Kiesel VM7 guitar:
https://www.reverbnation.com/grandfusio ... 4-riffraff
Land of the Lost
Postby Brian Johnston » Sat Jun 02, 2018 8:41 am
A quick jam put together this morning:
https://www.reverbnation.com/grandfusio ... f-the-lost
Summer Surf
Postby Brian Johnston » Mon Jun 11, 2018 6:39 am
An instrumental I put together using the Surf Trem by Carl Martin:
https://www.reverbnation.com/grandfusio ... ummer-surf
So Long, and Thanks for All the Fish
Postby Brian Johnston » Tue Jun 19, 2018 10:15 am
Instrumental using the Red Scorpion 2 distortion pedal:
https://www.reverbnation.com/grandfusio ... 25-so-long
Tropical Chill
Postby Brian Johnston » Mon Jul 02, 2018 8:03 am
A brief instrumental using the Kiesel Vader VM7 and the Surf Trem (tremolo) with Red Repeat (delay), going through the clean channel on the Le Lead Preamp:
https://www.reverbnation.com/grandfusio ... ical-chill
Suddenly
Postby Brian Johnston » Wed Jul 18, 2018 10:13 am
A new instrumental using my new Maple Leaf Royal Drive:
https://www.reverbnation.com/grandfusio ... 9-suddenly
Arabian Heat
Postby Brian Johnston » Tue Aug 07, 2018 10:58 am
Air (with Rockaway Archer pedal)
Postby Brian Johnston » Sun Aug 19, 2018 10:06 am
Playing around with various EQs and Gains on the Rockaway Archer (Rockett Pedals):
https://www.reverbnation.com/grandfusio ... 923593-air
Pound of Feathers
Postby Brian Johnston » Thu Sep 06, 2018 7:50 am
Instrumental using the JCM800 pedal (Mystere) by Doc Music Station:
https://www.reverbnation.com/grandfusio ... f-feathers
Cerulean Blue (instrumental)
Postby Brian Johnston » Wed Oct 10, 2018 11:51 am
Lone Son
Postby Brian Johnston » Mon Oct 29, 2018 11:47 am
Adding some high-gain to some Country type tracks (although it gets heavier in a few spots). Using Band-in-a-Box http://www.pgmusic.ca for the backing tracks and sounds.
https://www.reverbnation.com/grandfusio ... 8-lone-son
Casual Strain
Postby Brian Johnston » Sun Nov 11, 2018 8:42 am
Feel the Wave
Postby Brian Johnston » Tue Nov 13, 2018 9:17 am
Darkness Grows
Postby Brian Johnston » Sat Nov 17, 2018 8:46 am
Infusion
Postby Brian Johnston » Mon Nov 19, 2018 10:46 am
Two hours to kill and I thought I would compose something of a modern tone mixed with some Latin cha-cha type backing tracks. Guitar is a Kiesel Vader. I have a Maple Leaf Royal Drive going into a Red Scorpion distortion. The Maple Leaf gain is only up at 9-o'clock, whereas the Red Scorpion is on, but the gain turned all the way down. The Red Scorpion adds some grit in the mix. Those two are running through a clean amp channel (Le Lead preamp) and into the Carl Martin Rock Bug (amp/cab sim pedal). Any harmony is via the Quintessence pedal (I added a 5th in a small dose).
https://www.reverbnation.com/grandfusio ... 32-infused
Crosshairs
Postby Brian Johnston » Tue Nov 20, 2018 9:13 am
A 1.5 hour composition and jam (I gave myself that much time to develop and record). Nothing fancy, but it's fun to riff things out now and again. Using a Vader VM7 through the gain channel of the Le Lead preamp.
https://www.reverbnation.com/grandfusio ... crosshairs
I Love the Way You Love Me
Postby Brian Johnston » Sat Nov 24, 2018 10:37 am
Originally had vocals and words, but my singing leaves a bit to be desired. It became a short instrumental:
https://www.reverbnation.com/grandfusio ... ou-love-me
Simple Promise
Postby Brian Johnston » Tue Nov 27, 2018 10:40 am
An instrumental combining dirt. I took a high-gain channel on the Le Lead preamp, which not only sounds modern, but a touch sterile (good to my ears, but you know what I mean). I added the Vintage Fuzz II (model 2 SA 202) with germanium transistors. I kept the Bias somewhat smooth (a hint of breaking up) and the Fuzz at about 11-o'clock. It produced some great harmonics, bites and a different dimension to the tone.
https://www.reverbnation.com/grandfusio ... le-promise
Playing a Kiesel Vader VM7
