zeus bass hard case option
jeffg777
Postby jeffg777 » Thu Mar 22, 2018 10:30 am
I recently received my ZB6 and love the softshell case. I want to have an option for when we stack guitar cases in the van. Does anyone know which hard case works or fits the best. Thank you. -Jeff
brento73
Re: zeus bass hard case option
Postby brento73 » Thu Apr 19, 2018 11:35 am
You may have already done this, but looking at the body dimensions, it seems that it will fit the hc8 bass cases from Kiesel. Other than that, you may just want to run to a local shop and try some on for size.
Edit: also, the hc28, used on the 8-string guitars, might also work. The neck width is about the same, and the body size is, as well. Since the Zeus is headless, the overall length should be fine. You might want to just call them to confirm.
