A70 Pickup Wiring
KurtCorpulus
A70 Pickup Wiring
Postby KurtCorpulus » Thu May 10, 2018 5:26 pm
I've got a pair of Carvin A70 active pickups that I'm looking to install in a 7 string and although I can solder, I'm certainly no technical genius. So I was hoping there was some kind of fairly basic diagram or instructions out there that could basically just guide me as to what to connects to where. Honestly, even a picture of a properly connected A70 circuit board would be helpful. Any help is appreciated.
Thank you!
Re: A70 Pickup Wiring
Postby spudmunkey » Thu May 10, 2018 5:59 pm
Does this help at all? Likely not...
KurtCorpulus
Postby KurtCorpulus » Fri May 11, 2018 11:01 am
Unfortunately not, I did actually come across that photo earlier and while it did help me figure out the wiring for the selector switch, I'm still trying to figure out exactly where the battery snap connector and actual pickup wires are supposed to be soldered to the board. Thank you though, really do appreciate your help!
X1Glider
Postby X1Glider » Thu Sep 27, 2018 9:33 am
Are you still looking for this info? If so, I can take a pic of my control cavity and e-mail to you. Would just need your e-mail.
