Pickup Mounting Ring Height
microzyma
Postby microzyma » Thu Jul 12, 2018 2:10 pm
My SC90 has two short pickup mounting rings for front and back pickups. I am going to install a PAF repro and am wondering if I should buy the same height rings for the new pickup. Reason I ask is that I noticed Les Pauls use a tall one for the bridge pickup. Thanks!
Re: Pickup Mounting Ring Height
Postby spudmunkey » Thu Jul 12, 2018 4:16 pm
I imagine Les Pauls use a tall one for the bridge pickup because the neck is angled back, and the bridge is so tall.
Postby Doctor Turn » Fri Jul 13, 2018 6:57 am
Bingo. I'd imagine the SC is a pretty straight neck versus the body, so there's no need to push the pup way up off the body to get within striking distance of string vibes.
aoresteen
Postby aoresteen » Mon Jul 23, 2018 1:38 pm
As a general practice I find it's best to use the pickup bezels originally supplied with the guitar. They will be the proper height.
I've installed a couple hundred humbuckers over the years and have had only a few problems. If a particular humbucker won't fit the original bezel, measure it with digital calipers and contact the pickup mfg for a bezel of the same height. You might have to modify one to get a proper fit.
I just dropped a set of Kiesel KL12N & NL12N pickups into a 2001 Squier Stagemaster Deluxe neck-thru. I used the original bezels but had to drill out the pickup mounting screw holes to 0.125" for the Kiesel screws to fit. I ordered the pickups for this application and Kiesel tapped the center pickup mounting holes for me.
Users browsing this forum: dunicus and 3 guests
