Distorted Tones and Noise from My New ZA7
SilkyHotLicks
Postby SilkyHotLicks » Sun Nov 25, 2018 6:43 am
Firstly, I think that my ZA7 is a great guitar and the Zeus Acoustic concept and execution should be considered as a 2018 best in show. You really need to play one if you haven't, preferably through a good acoustic amp :D
But now it's only making very noisy, distorted and high pitched tones. I've tried changing batteries, changing cables and finally switching amps but nothing fixes it. I think that the board needs to be replaced. I'm reasonably competent with electronics, is this something that I can do or should it be returned?
Re: Distorted Tones and Noise from My New ZA7
Postby gumbynotpokey » Sun Nov 25, 2018 11:26 am
Jeff says, "Call my guys". IMO that's your first move. Could be a warranty repair.
Overall, calling first is best for many reasons - after eliminating simple problems like signal chain, batteries, etc. Why? They need to know what they are doing wrong, and they need to know what parts last and what parts don't.
SilkyHotLicks
Postby SilkyHotLicks » Sun Nov 25, 2018 11:49 am
gumbynotpokey wrote:Jeff says, "Call my guys". IMO that's your first move. Could be a warranty repair.
Yep, I'll call them tomorrow morning. I only posted this because I remembered somewhere that output circuitry in some piezo systems have been known to hold a static charge that couldn't be dissipated properly. I was hoping that someone here had come across this issue before.
Postby spudmunkey » Sun Nov 25, 2018 12:19 pm
Try wiping the back of the control cavity with a dryer sheet. It can help dissipate static...read that tip somewhere, and it worked on a strat-alike.
Postby gumbynotpokey » Sun Nov 25, 2018 2:03 pm
spudmunkey wrote:Try wiping the back of the control cavity with a dryer sheet. It can help dissipate static...read that tip somewhere, and it worked on a strat-alike.
I've seen that done in-person and it does remove fuzz/static (no pun intended).
SilkyHotLicks
Re: Fixed! - Distorted Tones and Noise from My New ZA7
Postby SilkyHotLicks » Mon Nov 26, 2018 2:33 pm
I tried to call support but they are swamped. I forgot it's cyber monday and I finally gave up after three consecutive calls for a total of a 30-min wait with no help.
I thought that maybe I used an 'OLD' new battery for testing and I went to the store and bought a ''NEW' new battery, still no good. So next I popped the top on a Stella Artois, took a long swallow and decided to plug the guitar in one more time. Boom! its working again! :wall:
