Active Electronics on Carvin LB75 not working
Moderators: Kevio, ElfDude, JesseM, ChrisH, Bundy, RockCrue, soundchick, peb, Albert C
jhaxton
Postby jhaxton » Wed Sep 16, 2020 12:03 pm
I'm hoping for some help troubleshooting a "no output" situation on my LB75. I'm the original owner, so I know the electronics haven't been messed with. I had intermittent issues with losing output with the active switch engaged for a short time. That transitioned quickly to no output at all when in active mode. Any advice on how to troubleshoot or fix the issue?
I am hoping that since it was intermittent before it stopped entirely that I may not need a new preamp.
Thanks so much!
Re: Active Electronics on Carvin LB75 not working
Postby gumbynotpokey » Fri Sep 18, 2020 6:15 pm
New batteries?
Postby canon_mutant » Fri Sep 18, 2020 6:40 pm
Or, just bite the bullet given NO support for Carvin and start your discreet wiring to split the pups and in/out phase.
This gets you close . . .
https://www.seymourduncan.com/images/wi ... PHppSP.jpg
jhaxton
Postby jhaxton » Mon Sep 21, 2020 8:16 am
canon_mutant wrote:Or, just bite the bullet given NO support for Carvin and start your discreet wiring to split the pups and in/out phase.
I appreciate the info. Thank you!
jhaxton
Postby jhaxton » Sat Jul 17, 2021 1:42 pm
Update: After well over a decade without the active EQ working, I took a chance and did something crazy. I cleaned the push-pull pot/switch. You know what? That's all it needed. Doh!
Postby spudmunkey » Sat Jul 17, 2021 2:35 pm
jhaxton wrote:Update: After well over a decade without the active EQ working, I took a chance and did something crazy. I cleaned the push-pull pot/switch. You know what? That's all it needed. Doh!
:lol: Well, hey...I once built a brand new computer, and used it for 3 years disappointed by the performance, and it turned one that after moving it to our new home, somehow the monitor got plugged into the motherboard instead of the actual graphics card. :wall:
